Phil Fouracre
Yup! Great stuff, in all our tyres - I reckon we could get this past 5 pages just between us!:-)1 vote for Slime, and to get this thread moving towards page 5.
so what?This is a cycling forum.
Well, it is! Wouldn’t be able to cycle if not! :-)cycling and/or repairing a puncture isn't everyone's priority
The OP should have found out already if his bike was set up tubeless or not WAAAY BEFORE his first puncture and with no need to remove the tyre.
My Giant TCR is set up tubeless and every time I squeeze down the valve when I top up my tyre pressure, a few drops of sealant squirt out.
OP, when you top up your tyre and squeeze your valve, does some white liquid squirt out?
Yes = tubeless
No = tube
Who’s Alan Armstrong? Is he on GCN?Alan Armstrong and Richard Osman present "Tubeless", where contestants aim to work out if a bicycle has inner tubes or not.
Can they do it within the mere 48 hours allowed???
You can remove Schrader and Presta cores! And, before anyone says anything you can ‘get past’ the older presta cores that weren’t removable - nip the end off the threaded pin, unscrew the nut and drop the valve into the tube - add sealant and reverse!Yes you can remove Schrader cores and add sealant.
Who's Alexander Armstrong? Is he on GCN?
Answer at last down the page. What a relief.Oh! Come on! What is the answer? I can’t wait any longer - Is it tubeless or not???
It’s tubeless. I’ve tried to plug it which wasn’t easy! Hopefully it’s done the trick but I can see why maybe inner tubes are a simpler option.
