Ming the Merciless
There is no mercy
- Inside my skull
If it’s dry and warm, repair side of road. If cold and / or wet then bung in spare tube and repair at home.
thats what im trying to say......going tubeless only makes it smoother....You could still get a puncture by just going tubeless
I happened apon a fella a while ago standing looking at his phone with no signal, when I asked him if he needed help he pointed to the several inch wide tear in his tubeless setup, ain’t no tube or patch gonna fix that bad boy and the nearest landline was in the pub six miles away down a very steep hill.
not a puncture related story but more on the being prepared when out riding, I rarely go off road mostly because my MTB skills are terrible. Nevertheless I decided to go off-road proper and sure enough had a low speed fall onto my knee, only when I stood up I could see my kneecap through the cut. Fell onto flint covered muddy trail which cut through me like a hot knife through butter, 10 miles from a road and no mobile signal I needed my spare inner tube and an arm warmer to stop the bleeding.
moral of the story tubeless or otherwise always carry a spare tube oh and a field dressing if you go mtb’ing
Most glueless patches will struggle if the puncture is near a prominent seam/ridge on the tube. Most also won't stick well on the edge of another patch. If one doesn't work, remove it and try again, but the tube may be junk. I view them as a short-term get-you-home quick fix. Holding them down to heat them up for 30 seconds or so helps.They are just adhesive type patches, no glue, press and hold.
The moral is carry a tube because you never know who or what you might need it for
Not quite. Wise people use Woods valves: Schrader-size hole in the rim, presta-size pump attachment, plus a valve that only ever lets air in. The core is unscrewed if you ever want to deflate.Spare tubes come in two valve types, car tyre style presta and racing style Schrader.
I don’t like Continental tubes personally. Ignore the C, you need a 700 tube that covers the 32 bit, eg https://www.halfords.com/cycling/bi...presta-inner-tube---700c-x-23-32c-525334.html they come nearly packed too 👍 (assume you have the long skinny presta valves not the schrader car type ones if that’s your bike in avatar) 4 for £10 is a bargain
get yourself some of these while you’re at it
https://www.halfords.com/cycling/bi...e-reinforced-bike-tyre-levers-x-3-220160.html
So have I. I’m absorbing this thread with interest.Great, that's exactly what I needed!
Do you also have a preference on a multi-tool which can be slipped into the saddle bag?
Would you say that these are the minimum things you need to take on rides:
1) Pump
2) Repair Kit
3) Spare Tube
4) Multi-Tool
.....and yes, I've been out riding with nothing !!
