Tigerbiten
No, I've done it by hitting a curb at an angle.Can it be that the Trice Q is impossible to flip ?
As I was leaning the wrong way at the time, this flipped the trike.
the little KMX has a rack battery done about 50 miles now and the balace seems great. the performer has 2 dolphins attached to the seat. and the other kmx has another rack battery. have had a big run yet but seems steady enough.EAPC regs states on an electric trike all wheels should be braked .
On a standard "geared brushless motor " there should be almost zero drag as the motor drives though a spray clutch system that allows the system to freewheel when not in use.
I had a rather heavy battery pack rack mounted above a 26" wheel and yes it flipped very easy .
The 36v 10ah LiPo4 batteries l have on a couple of trikes are mounted about 4" above the ground . They keep the cg low.
My bottle batteries screw into the seat back and the weight doesn't affect the handling , even when thrown about .
we have had 40+ mph on down hill runs and the trikes are still stable with 160 - 203mm discs fitted , 180 front and rear are enough to stop you in a hurry!
regards Emma
I haz a handbrakeEAPC regs states on an electric trike all wheels should be braked .
regards Emma
Grin. The youth of today
