First Commute and looking for lights
Tom Hooper
northumberland
just done my first commute didnt think i needed lights at 8am as its still light but i think i was wrong, what recomendations can you guys give me?
this is to be seen not so much to see with light as i will be mostly on roads with street lights in the winter.
thanks
ianrauk
Tattooed Beat Messiah
Rides Ti2
You will get a 101 recommendations from the good forumites. Everyone has their favourites.
Myself.. for winter commuting I run 2 Hope Vision 1's. One on static, one on flash mode.
Tom Hooper
Tom Hooper
northumberland
I should say i have about 50 quid for one decent front and back lights then can get some smaller lights for forks etc, i like the look of knog blinders
Kookas
Exeter
I can dazzle people in broad daylight with my Moon Comet rears. £20 each.
By the way unless you're willing to try the Chinese Magicshine rip-offs, £50 will only get you be-seen front lights - generally with a max output of 100 lumens.
Say you've got £30 to spend after buying rear lights.
Lezyne's new Hecto Drive and Moon's front Comet both output 100 lumens, but I wouldn't recommend the front Comet just because the way it shines isn't suited to a front light IMO. Too blinding.
Lezyne is also a bit of a style brand though, so their prices tend to be a little bit higher for the same stuff.
I don't have much experience outside of that, and I haven't been as satisfied with any of my front lights as I am with my rear lights. Most likely because proper front lights are so costly.
Moda
Recently went through this myself but one thing that's worth considering is how your going to power them especially if your a regular commuter. The cost of ordinary batteries can be a real money pit and rechargeable can be a bit of a pain in logistical terms ensuring they're fully charged when needed.
Although a fairly costly option I went for a set of Exposure lights.
Amack
Agree with Kookas, I have a Moon Comet rear and it's fantastic, recharging is quick and easy via USB. Great light
Kies
The moon comet is a great light. On flash mode, always get wide passes.
The moon meteor front light lasted one year so not impressed at £50-£60.
Decided cheap cree T6 lights are they way forward.
But stay with the rear moon and a battery operated cateye as a backup
Deleted member 20519
What mudguards are those?
Kookas
Exeter
Crud RoadRacer MK IIs. They might be the only mudguards you can fit in the tiny clearance the T3 affords.
Kies
Tangent to the initial OP question - anyone seen front fork mounted lights?
Saw one today along embankment and it was very affective with a normal bar mounted device
Kies
I have those on my T3 aswell. The rear fits really well, front less so. In fact i couldn't get the front to fit under the brake caliper without rubbing on the tyre. So some creative licence to sort that one out
Kookas
Exeter
My front mudguard got thrown away by a relative, so I only have the rear anyway.
Ah, I tried them last Winter but they didn't work out too well. They were constantly rubbing and then one of them got sucked into the wheel so I gave up.
