GregCollins said:In the past I've done a few BP's and short Perms, on various MTB's, Nexus hub geared hybrid, and one on a Brompton. and of course on my current tourer. Run what you brung and all that.![]()
Don't know about Shimano but all Campag triples will do 26T.Shimano/Campag won't do less than a 30T.
Tim Bennet. said:Greg - you said your bike was going to have Campag. So don't let your experience with Simano Sora and STis in general put you off. Mid range Campag Ergo levers are reliable enough.
andrew_s said:To revert somewhat, if you are heavy and prone to hitting potholes, you will want wider tyres. If you used 23mm you'd need to keep them at about 115psi to avoid pinch flats, and that leads to a comparatively hard and uncomfortable ride, and insecure handling on rough descents. If you use 28mm tyres, you can drop the pressure to 90-95psi, which helps both comfort and the ride.
With modern "standard" brake calipers (49/50mm), your tyre limit is 23mm with mudguards or 25mm without (generally).
With "deep drop" dual pivots (57mm), you can go up to 28mm with mudguards, or 32 without.
Noodley said:I have 53-40-30 and 13-29.
GregCollins said:certainly aiming for a 13-29 Veloce cassette. Will suck and see on the chainrings. I'm sure the guys at Spa can source me some alternative ones if need be later. I doubt I spend much time in the big ring!![]()
GregCollins said:I just went on Spa's website. A Sabbath September Rival - ti frame carbon fork Audax bike - for less than £1500!
*faints*
Tim Bennet. said:No it's the frame that dictates the callipers. A frame or fork that has clearances for wheels with 25mm+ tyres and mudguards will probably need a 57mm brake just to reach down to the rims.
Whether you then choose to fit big tyres and guards is up to you.
The choice of 57mm brakes is Shimano (the one that's Ultegra standard).
P.H said:That would be some Audax bike!
Two things to note, SRAM is only double rather than triple.
I read on the CTC forum that SPA charge the customer 10% extra to proccess the cycle to work voucher (Which is probably still better than most shops charging RRP)
