jpembroke said:
as I said above, put the pre-cut neat end of the outer cable in the ergo (without a ferrule) and the cut ends that you make in the frame's cable stop with a ferrule on the end.
I've done the brake cables now. What I've done is put the raggedy end in the ergo lever with a ferrule and the neat end in the cable stop on the brakes. As I said the brake cable stops won't accept a ferrule so I'll need to think some more on this when the outers are replaced,which is why I've gone against the above advice, good though I'm sure it is.
I've used a couple of small files per the Park link Bonj gave, a pointed one as an awl and a flat to smooth the edge. It's nowhere near as neat as the supplied cables - which are so neat they're nearly a work of art - but it'll do for now. There's a cable outer guide within the frame top tube which allows me to connect the brake outer direct to the rear brake so there's no frame stops involved in the brake connections.
The next issue will be the cable for the rear mech. Unlike the brakes the mech cable stop WILL accept a ferrule, but the frame stop won't. It's an older style frame with downtube shifter braze-ons, so it probably pre-dates the modern style gear cable, so was expected to accept the steel coil type outer. Unfortunately the new style cable,with it's pointy metal bits, will quickly strip the paint from the frame stop without some protection. Anyone got any ideas?
Thanks for all the suggestions so far, and please bear with me. I'm a novice just trying to do a good job.
(Not a quick job though, obviously
