Finish at the valve when seating a tyre?
BillyS79
When fitting a new tyre or fixing a puncture do you finish at the valve?
I was always taught to finish at the opposite side from the valve, but just seen this -
View: https://www.youtube.com/watch?v=jvvXrlAUUfU
Which way is the right way?
Not sure why he talks about it being easier, especially with tubeless tyres, as you can push the valve in to give more slack - I don't see how the valve affects the level of slack in the tyre, and aren't tubeless valves bolted to the inside of the rim to impossible to push in?
slowmotion
Quite dreadful
lost somewhere
I don't know if it's the right way but I always end as far away from the valve as possible. I don't like the idea of stressing the valve stem as I struggle with getting the last bit of bead on.
Will Spin
Works for me with clincher wheels and tyres. Push the tyre well down into the well between the rims start opposite the valve and work both sides around to the valve, this gives enough slack to pop the tyre bead over the rim at the valve, the tyre always goes on very easily if I do this.
Starting at the valve increases the likelihood that the valve seat will end up under the tyre bead, preventing the tyre from dropping into the rim, reducing the amount of 'slack' and making it tighter at the last. Increasing the chances of mullering the valve and increasing the effort required to persuade the tyre on to the rim.
Start at the rim joint - and finish at the valve. Always.
Randy Butternubs
Starting at the valve increases the likelihood that the valve seat will end up under the tyre bead [...] Start at the rim joint - and finish at the valve. Always.
I start and finish 90 degrees from the valve - it avoids both problems...
...when I remember that is. It doesn't usually matter at all.
Dan B
Disengaged member
I put one side of the tyre on the rim, then valve through valve hole, then a small amount of air in the tube to give it shape, then put the other bead in starting at the valve.
