Feeling it in my shoulders....
I had my 3rd ride on Sunday morning. I got in just over 20 miles with just over 1,000ft of a climb.
I suffered the usual sore #rse but was really feeling it in my shoulders, is this usual? I'm fairly sure the bike is set up correctly for me.
Cheers,
Adam
mjr
It doesn't sound usual. It sounds like the bar position is wrong but it could be the saddle fore/aft position.
Hacienda71
If you are not used to riding yes your body will take time to get used to the new position you are holding it in, particularly if you are riding a bike set up in an aggressive position i.e. low bars and long stem. As your body adapts then you should ache less. If you are set up wrong you are more likely to suffer pain in the knees, feet, the hands and wrists.
winjim
I expect you're tensing up whilst riding. Relax your arms, unclench your teeth, engage your core.
I have just returned to cycling after a longish hiatus and I also have sufferred with this. I think most of it is down to your body just getting used to it.
I would not rule out getting a proper bike fit even if the pain goes away as they are well worth the money (if done properly). I had a professional bike fit on my old bike and I remember one winter I missed about 2-3 months of cycling due to the weather (and also my laziness) but once I started again after that relatively short lay off I experienced the achy neck and shoulders for a brief time.
ayceejay
Rural Quebec
This is where core strength comes into the picture, if you are supporting the weight of your upper body with straight arms and no back up from your core you will get sore shoulders. As others have said, this will improve the more you ride but you could supplement this with some exercise specifically for core strength, Try to look at your technique too as being a beginner you may not have the necessary flexibility and will need to switch your hand position more often.
Katherine
Manchester
Pilates.
Aaaarrrr
Oh Pilates, not Pirates :biggrin:
