02GF74 said:now that we're onto non bike bodges.
best one I heard was of a crack in a Land Rover chassis - rather than repair it, a microswitch wired to a lamp was fitted to indicate when the chassis would fail - the lamp would flash as the car was driven over speed bumps!!!
bobg said:now all the 5 and 13 amp ring mains wouldnt reach the fusebox! Extended them all with 6 inches of cable secured with those little screw swichblocks copiously covered with insulation tape
gbb said:In my early (and skint) driving days i had a Mini van.
On a trip, the brake lights failed...i knew the bulbs were ok, so checked the wiring..it seemed ok,
Tracked the wiring back, to the brake pressure switch in the engine compartment...hmmmmm, failed switch maybe.
Disconnect the two wires from the switch, added enough wire to each so they'd reach the passenger seat...
Instructions to the wife.....when i brake..i say 'brake' and you touch the two wires together...brake lights come on. It worked
It was only supposed to see us till we got home...but being skint meant it lasted considerably longer![]()
Paulus said:Mine was three years ago, touring in Provence when the bracket that holds the mudguard stays to the mudguard snapped. Some thin wire from a French fence was put to good use and it is still there. The mudguard still rattles a little, but it is still in place.
