Favourite temporary bodge that became permanent
SilverSurfer
I went from fixed to SS then gears, simply because even though I loved riding fixed I wanted versatility for non-sweaty rides and carrying stuff. Oh alright then, I'm bone idle.
So I chucked on a worn 38T ring (no front mech), an old 11-28 cassette, an old LX rear mech and bodged a D/T shifter from a friction MTB thumb shifter with a long bolt bent around the D/T.
It was only meant to be a quick fix until I got some proper bits - but I found it perfect for my needs. Chain has never jumped off the front, even over severe pot holed roads and the clicky friction changes are a doddle now. I thought a top gear of around 91" might be a bit small, but it isn't at all.
Any similar bodges?
gbb
Peterborough
I fitted a new set of Gatorskins...and promptly got a 6mm slash in one of them within days :biggrin::ohmy:
It didnt puncture...just left a (slighty) gaping wound in the tyre :wacko:
I just spent £17 on each tyre at the time...i'm a tightwad, and i'm not paying again, so i inserted a strip of emery tape ( like sandpaper, but for metal. Very strong backing) in the tyre to stop the tube bulging out the gash.
Its still going, maybe 2000 miles later.
peanut
didn't have a suitable 26mm seat tube for an old 501 frame so wrapped some masking tape round the seatpost to pad it out. Works a treat . been there about 11 years now !
longers
Cheers gbb, you've just rescued a gatorskin of mine with 500 miles on the clock that had an accident with a large piece of glass - 10mm gash :wacko:.
Joe24
Nottingham
On my folder, i had half the bolt drop out( was a strange bolt) I never noticed and when i did notice, i wacked in a long thick alan key and rode it.:ohmy: That stayed in for a while, then i got road to fitting a proper bolt. Whcih is why you should never buy a cheap folder.
I'm quite enjoying the cable ties that hold the mudguards onto my mtb commuter (the one that used to have aero-bars on). :smile:
Mind you, cable ties and gaffer tape are bona-fide bike parts aren't they? :smile:
Joe24
Nottingham
On the old cheap BMX i had, the clamp which held the saddle kept moving around. So i got the ductape out from the car and wrapped it around the saddle. Put a load on tight and i was done. Seat would only move very very slightly then. That stayed like that for ages, i think i ended up taking it off when it had seized in place :smile:
