antnee
- Weston Super mud, North Somerset
Looks OK but I note no tight link cradle.I've been using this one (from Decathlon) for several years. I must have unlinked/linked about 40 chains so far. It's still going strong.
The Topeak one on the multi-tools is the easiest one I have ever used. The design of using a hex key on the other bit of the tool to turn it is the best sort of simple clever design. I have a workshop tool from a major company which is a pig to turn.
It's a second cradle.What is a tight link cradle?
Now and again (not often but a pain when you do - and it is sometimes the reason for a chain skipping for no obvious reason) you get a tight link. The second cradle allows you to loosen it.
If a link is tight you can see it if you back pedal when the load is off.
