Hello all
I can't believe I'm considering this but... The N+1 BUG is hitting and I was considering a drop bar winter trainer / yearly commuter (to justify its requirement). Being a fan of Genesis, I'm interested in the Day One range, particularly the 2016 model : http://www.highlandbikes.com/m1b230s23p5896/GENESIS-Day-One-20-2016
It uses a Nexus 8 hub (replacing the Alfine 8 from 2015 to cut the price down). I've read that this type is nearly maintenance free and has a good speead of gears.
Does anyone have experience using one of this hubs? Are they really bomb proof? Is it easy to change gears with the little lever sticking out of the drop?
Also, if you get a rear puncture, how easy is it to remove the wheel with the hub / disc brake arrangement, or then fit it back and get the right chain tension etc.
Any suggestions would be very welcome. Thanks for reading.
SM
SM
