exchanging loose ball bearings? and what grease?
young Ed
in replacing the 9 1/4" ball bearings each side of my rear hub i was wondering could i replace the loose ones with caged ones or sealed bearings? are there any advantages or disadvantages in doing this? and what grease should i use, lithium grease?
Cheers Ed
Tim Hall
Crawley
You'll not be able to use sealed bearings. You can use caged bearings, but I wouldn't bother. in the past I've had the odd spot of bother with the cage getting twisted.
General purpose lithium grease will be fine - get a big tub from a car accessories shop. It'll last ages and is a lot cheaper than a wee packet from a bike shop.
02GF74
I've never had any problem with caged bearings. There is a school of thought tht says use loose bearings as you can fit one or two more than come in a cage.
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
when you think you've got enough grease in, put some more in.
young Ed
young Ed
okay plenty of grease and a bit more and then strip and clean and re grease with some extra grease yearly got it
Cheers Ed
P.S plenty of grease,plenty of grease! hehe :biggrin:
young Ed
young Ed
do yo mean keep them loose or loosen them off then clean them and tighten up correctly again?
Cheers Ed
