Essentials for a saddle bag?
jonny jeez
Hi all,
I'm just about to start going on longer rides as training for an event. At least to start with these will be largely solo and a fair distance from civilisation.
First question should really be - is a small saddlee bag essential or should shirt pockets be able to carry everything? Secondly - what are the essential things to carry?
Symon
Whilst purists and the velominati all frown on the deployment of a saddle bad, let's be honest carrying all the stuff you may need can create a really uncomfortable weight in your pockets that pulls at the front of the jersey all day.
If it's summer, I can get away with pockets, in the winter I can't as my pockets are already full of gloves, arm warmers and a rain shell.
So I tend to resort to the slimmest of saddle bags but even then it has to offer zero rattles (packing it with latex gloves helps), zero movement (bracket under the seat and strapped to the post ) and finally is as tiny as I can make it.
Oh and strapping other stuff to your bike is so "common dahling", Especially when the best jerseys come with a retaining loop in their pockets, just for the job...that has to be pro...right?
Sorry...did you just say attach it to the frame?
@vickster , that's 5 demerits for you.
Only 5? Damn must try harder. :whistle:
Being a woman on a roadbike must make me a leper in the eyes of the velominati anyhow!
raleighnut
I don't know about this gloves lark. All you nancy-boys scared of getting dirty hands. More seriously aren't thin gloves going to split and thick gloves make it too fiddly to do the job. Just wipe your hands in some grass.
Don't, as my Dad insisted, stuff a rag under the seat to wipe your hands. If it falls down into the chain jamming the wheel against the frame 10 miles from home without a spanner
The rag under the saddle is an old Brooks riders trick.
Dogtrousers
Lefty tighty. Get it righty.
While marvelling at the engineering miracle that is my new Brompton I note that there seems to be loads of room inside the main tube. Enough for ... Ooh a pair of socks, or some phials of EPO, or a Curly Wurly ...
mjr
Back in the 70s we all had a yellow duster rolled up and stuffed in there round our way.
Yes, well, how else would you identify a supporter of the Liberal Party?
Has no-one suggested a saddle!? ;)
There are a lot of items to carry: not all will be required, but you'll have to work/find out what is necessary and relevant for you.
You may want to try using a Topeak (for example) bag. They look bulky and clumsy, especially on a road bike, but they'll do the job of carrying your essential pieces of equipment.
https://www.google.no/search?q=tope...ved=0CAYQ_AUoAWoVChMInu353O37xwIVRv5yCh31_Asc
sbeqs
I read as far as ''Cake money'' and thought ''What else after this could possibly matter?''
Supersuperleeds
Leicester
I carry, two tubes, a swiss army knife, tyre levers, co2 and normal pump, bike lock, credit card, bank card, cash, phone, rucksack that stuffs into itself and a couple of chocolate bars.
I use a triangle frame bag and a saddle bag.
mrandmrspoves
Middle aged bald git.
Narfuk
Tool kit including Crank Brothers multi tool featuring chain tool,spoke key and common Allen Keys. A adjustable spanner and 10mm ring spanner, 30cm length of wire, small assortment of nuts and bolts. A couple of cable ties and an old toe clip strap (last used when my overloaded pannier rack came loose) Two inner tubes ( plus a 700 X 28 in case someone else needs it. Quick links x 3 to cover anything between 6 and 11 speed) A can of emergency tyre sealant, a pair of tyre pliers and 3 tyre levers, a length of cut inner tube for use as a tyre boot, a crank extractor (which is much more likely to be used to fit a crank that was not torqued tight enough on someone else's bicycle and has been used twice in the last few years for this very purpose). A small can of aerosol spray oil because squeaks are so annoying. First aid kit including microfleece towel, polythene bags to put small body parts in - or more likely, blackberries or other hedgerow pickings, a wad of cotton wool within the kit can also be used to run around the inside of a tyre following a deflation as it will snag on any sharp object that has penetrators the casing. A cafe lock +/- a D lock and cable, depending on destination and intended cake stops. A set of small battery lights in case of failure of the ones fitted on the bike or in case someone else has forgotten theirs, a hollowtech pre load tool (even though my trike and bicycle don't have a Hollowtech BB and a 20p is a usable alternative . Waterproofs - which I tend not to wear when it is raining due to my dislike of 'boil in the bag syndrome', 3 X cereal bars, anti-histamine tablets, Codeine tablets, Salbutamol inhaler, a packet of tissues, a couple of pairs of non latex gloves.
Then on the day, mobile phone and wallet.
All of the above are basic essentials and any item removed from the list will inevitably be required on the very next ride.
