GuyBoden
- Warrington
Is it still cheaper to boil the kettle with gas?
Funny that I think they are the pits, I got their free repair service included in our package, called them up as the boiler was leaking water, after 2 cancelled appointments he turned up, I explained what the issue was, 'Oh I know what that is, it'll only take 5 minutes' he put air pressure into the expansion chamber as he bled water out of the system. If was then tested & all was working fine, he then stuck a probe into the flue at which point it all went pear shape. The boiler had to be condemned, it's dangerous, can't leave it working, you're lucky you're still alive etc. etc. oh we can't get parts for it it's too old, this was without any investigation then promptly capped our gas supply off & left.What I would emphasise though is I find their engineers excellent.
I might start using the meths burner from my camping kitIs it still cheaper to boil the kettle with gas?
That's all I ever use so I hope soIs it still cheaper to boil the kettle with gas?
Has anyone been able to access BG to provide the readings for yesterday?
You'd have to add in the energy used for all the components, plus the calories of food you'd need to consume to replace the energy burned.![]()
The meter here suggests the shower costs 1p-2p/min or in that range, so I was surprised by the above, searched the web and no, indeed, electric resistance power showers are that awful. For comparison, our heater's maximum input is 3.5kW, but it rarely uses that (right now it's heating some water at 2kW) and heats a 170L tank from 16 to 47 degrees in 30-40 minutes... and we had to tell the grid operator we were connecting it! Why the fark are resistance showers advertised as "more energy efficient"?I can tell you how expensive it is to run a shower for an half an hour - £1.50 - 10KWh x 30 minutes x 30p per KWH.
Now you are getting technical.
I've worked out I can cycle 53 hilly miles on two pieces of toast, a bowl of cereal, a banana, some carb drink and an energy gel. Cost less than £1.50 - still cheaper than the car.![]()
Scottish Power website still down, but they have a holding page/form where you pop in your account number, postcode and readings and press submit.
Only issue is finding the account code - top tip, search your inbox for the dreaded email that arrived in early March about the price increase - account number is there !
