Energy bill increases
jowwy
Can't spell, Can't Punctuate....Sue Me
I think it's just an experiment to see what people are prepared to do, I would think that the peak time is 4pm until 7pm & they are trying to come up with a way to encourage people to consider their usage between those hours. If they can reduce the peak, then presumably they can refrain from building the network up further, or at least in the short term.
However the cynic may say they are also experimenting as to when they put the high rates in to curb demand via Smart meters
but we all one one fixed rate at the moment via the government unit rate cap ( if on standard flexible plan)......and as we are contracted for that and not for low peak and high peak tariffs that wont change......unless your on their agile plan
Deleted member 26715
Perhaps a bit earlier.
Yes it was very much a finger in the air type of guesstimate
I have no faith that will not be the case, I feel, again a very much finger in the air type approach, that within 5 years peak rates will be introduced to try to flatten the demand peak.
jowwy
but we on solar my man.....you and i will be good, cause we made the jump to be partially sustainable
mjr
Agile and various economy 7/6/4 tariffs are still in use, but not all are open to new switchers at present. As well as some people still on long cheap fixes. It's not true that everyone is on the 34p/kWh flat cap.
jowwy
look at what i put in brackets
It's not good at this time of year, mine has done very little for the past few days
Alex321
South Wales
Their agile tariff is based on the half-hourly rate wholesale rate they are charged. Both for import and export (but with different multipliers so they make a profit, obviously).
And that half hourly rate is almost always highest between about 4PM and 7PM.
Alex321
South Wales
already on 5kwh's for today......not a cloud in the sky since 8am
We're only about 30 miles South of you, and haven't seen any sun so far today. Battery has gone up from 5% to 12%, where each 1% is about 0.16kWh, and it is showing 0.365kWh "production", so a total of round about 1.5kWh generated so far.
jowwy
we on 6.3kwh.....but remember i'm 1600ft (approx) above sea level, the fog has been below us in the valley
Petrichorwheels
I think that's the point.
If they're asking you to go without electricity for the evening - who would do that ?
This is just taking the peak off the demand.
Start cooking after 6pm instead of on the dot of 5.
Why so suspicious?
Not suspicious at all - just that I would have expected the "reward" to be at a different timeslot.
