Electronic driving aids - love, hate or indifferent?
gbb
Peterborough
Do the electric handbrakes still have cables ? I've seen two cars rolling into traffic because the cable slipped or broke ? I've no idea if that's an improvement or not ?
No, its a motor.
Switch operated, supply goes to motor, actuates the brakes. Disengages by reversing polarity, retracts brakes?
I have it on my Mazda, its neither here nor there, I can't feel any advantage or disadvantage. If it goes wrong, I don't doubt it will be more expensive to repair but having done a couple mechanical handbrakes in my life, they could be difficult to access anyway, no fun in them either.
I don't hanker after the past particually, its progression, some we definitely benefit from, some we don't, its not going to change for me or anyone else so why bother...getting bothered.:okay:
My Kodiaq has, and I don't like;
1. an electronic handbrake
Sometimes (for example) approaching traffic-lights, you're practically stationary, & the lights change, it will engage, & has to apply in order to disengage
It (like others, I assume??) operates the brake-lights, when it's engaged, after stopping via the footbrake, shining straight at the driver behind
I don't like that happening to me, so I guess others don't!
2. keyless/push-button start
Sometimes it'll take 4 or 5 attempts before it starts
What was so wrong with a normal key?!??
I'd like it to have;
1. full LED lighting, including headlamps & interior
2. I hope not to need it, but a matching spare-wheel, the road-wheels are '235' section, & the spare is a '215'
3. reverse camera & dashcams (f & r) integrated into the touchscreen
Electronic ignition, tubeless tyres, ABS, traction control, even cruise control, so far so good. Auto wipers, a mixed blessing. LED lights, well worth having. Auto headlights, well I was a bit sceptical at first but they seem to work OK on the last two cars I've had. Auto dipping headlights that only respond to oncoming lights of a pre set intensity? Not so good, as they take no account of pedestrians, cyclists or horses. I've set mine to manual. As soon as the ignition is on, lighting up like Xmas tree which seems to be out of your control. You can't just get in the car without lighting up the neighbourhood, not so good if you have an early morning start and want to get off to work unobtrusively, or come back after working unsocial hours. It's the feeling of lack of control that annoys me. Lane management and proximity management are fine if they're set up property so that you wouldn't notice them in normal driving but I've had warning lights when cornering moderately when there's been a crash barrier which I presume the system has interpreted as a car. On a couple of occasions when coming to a halt behind traffic with a foot on the brake the system has increased the braking force unnecessarily. Keyless starting. It seems that the fob transmits continually, not just when the button is pressed. Therefore the battery life is not great. Another unnecessary gimmick.
Then we come to the issue of electronic handbrakes. If ever there was something that was a solution to a problem that didn't exist, this is it. The selling point seems to be the fear of being stranded due to a broken handbrake cable. Well, pardon me! In 42 years of driving I've never had this situation. If I had, I would not be running about in circles with my hands in the air. I would probably just park in gear (which you are advised to do anyway if you have an electronic handbrake) until I could get it fixed. If I normally parked on a hill I might source a house brick to put in front of a wheel for added security.
After having a 2006 VW Passat for 7 years and having got through three brake calipers, on one occasion being stranded on my drive until my breakdown service came and disconnected it so I could get to my local garage with warning lights flashing, sirens blaring etc to get the third one replaced, I swore never to buy another car with an electronic handbrake. Meanwhile I bought a car with a conventional handbrake. This developed its own electronic issues once I'd got to 100,000 miles. Random warning lights, going into limp mode, no cause shown on diagnostics. It's ironic that modern technology allows you to maybe get 200,000 miles from the mechanical side of a car but the electronics start to suffer after a a few British winters.
Before cars had so much investment in electronic management systems my strategy of buying a fairly new car outright and keeping it for enough years to get my money's worth seemed to be effective. My last few cars have rather disproved that. Currently have a SEAT Ateca because Mrs T liked it. It has an...electronic handbrake! It's hard to find the type of car that we want without one. Despite assurances that they've sorted out the bugs I'm not convinced. Nowadays she drives more than I do so if she gets stuck somewhere it's down to the breakdown service now.
DRLs. Shame there isnt an over ride that stops people driving at night with no rear lights as the DRL and dash is lit. See this all the time. This is where clever tech is beaten by idiots.
Sat nav, love it, but its another tech beaten by idiots. ^_^
After driving about in the car, what a relief to go out on my old school Honda motorcycle. Electric starter, front brake, back brake, tubeless tyres, electronic ignition, heated grips...and that's your lot. A kick starter would be nice to fall back on. The lights come on when you switch them on using your skill and judgement and a quaint old fashioned device called a "light switch". It goes where you point it. The only warning light you really have to worry about is the oil pressure light. If that comes on, you're really in trouble. The other lights are just for information. Neutral, Side Stand down, Indicators, high beam. Analogue instruments. No ABS, traction Control, warning lights for this, that or the other. If it's cold, you wear more clothes. If it's pouring with rain, you might get a bit wet. How have I survived for so long? It's just great.
slowmotion
Quite dreadful
lost somewhere
You should try a bicycle to appreciate the true beauty of simplicity. I triple guarantee that Elon Musk's slaves won't "upgrade" the engine remotely overnight.
