Up to 58 after today's ride should be over 60 by the end of the year then it gets hard as I riden lots of 64 to get metric centuries in but not much over that distance
As you can see easy to get to 61 with the Imperial and metric challenge should see that by the end of the year then it gets harderI've just ticked over to 58 too after a couple of longer, flatter rides recently. Only need 4 @59+ to get up to 59
After our ride together yesterday (your 300th imperial century!!!!!!!) I began to question whether my lifetime target of E100 might be just a tad under ambitious!At long last I have progress:
Your imperial Eddington Number is 115.
You need to do 9 ride(s) of at least 116 to increase it to 116.
You need to do 19 ride(s) of at least 117 to increase it to 117.
You need to do 31 ride(s) of at least 118 to increase it to 118.
You need to do 42 ride(s) of at least 120 to increase it to 120.
You need to do 138 ride(s) of at least 150 to increase it to 150.
You need to do 199 ride(s) of at least 200 to increase it to 200.
I had expected to be talking enthusiastically about plans for the future, but recent rides seem to have been an ever-increasing struggle, and ramblings about exciting new ideas would seem misplaced just at the moment. Maybe it's my tyres...
Only started this year and my current score is only 35. Is there a default setting I can change so that I can start at 45, or perhaps even 50?I did an E60 in my 60th year (60 60 miles in the year) and am considering trying to do an E65 in my 65th year in 3 years time. Current lifetime is E67. ( only started cycling at 45)
You have to plan ahead. Say you start aiming for 45 and get 45 rides of 45 miles in. You decide that it was fun and then aim for 50 ... you now have 50 more long rides to do! If you had planned ahead, you would probably have made the effort and done some 50+ milers as part of your 45 mile Eddington efforts.Only started this year and my current score is only 35. Is there a default setting I can change so that I can start at 45, or perhaps even 50?
Aimlessly doing different distances is a recipe for Eddington stagnation. For example, any ride that I do now under 71 (?) miles counts for nothing in Eddington terms.
Easy to get Eddington Obsessed instead of just enjoying the ride!
Where I live, my typical rides average 100+ feet of climbing per mile and nearly always with lots of 10% and some 15-25%. That means that it is hard work for me to make inroads beyond E70.This^^ and that's why I have said before that I don't actively chase after E numbers rather then let them happen. If I needed a couple of miles to put in the Eddington pot then I may do so but I'm certainly not going out of my way to chase them.
Either I am going to do Eddington, or I am not. If I don't think about it I will probably drift up to the low 80s and get stuck there.
If I lived somewhere like Leighton Buzzard (where I did a forum ride on Sunday), I would probably be churning out imperial centuries because they *would* just happen as part of my casual cycling. I did 67 miles on that sunny ride and would likely have added the missing 33 miles but my family were expecting me back so I didn't. The thing is, there was only about 2,500 ft of climbing. My local Season of Mists audax will be coming up in less than 2 weeks time - same distance, nearer 8,000 ft of climbing, some at 20+%!
I'm now at 68 & my next 2 70+ mile rides will see me hit 70 this year after all70 will probably be next year for me. Currently at 65, 6 rides of 68 needed to get to 68, so that'll be before the end of the year (summer if I get my finger out) but need 10 rides of 70miles to get there, so unless I do 2 70+ rides as well as my imperial centuries this year.....
Luckily it's rather flat here in East Yorkshire otherwise mine would be a lot lower, 101 miles today & 2200 ft of climbing
I did 2,500ft in 18 miles today
Fancy a swap?
