WhiteEagle197
The OP wants to know about Drive trains and how to achieve a better top end yes or no ?
White Eagle, to explain a little more. In your situation ( as I understand it, flatish roads ?) The difference between a 48 chainring and a 52 is going to be just over 1 tooth on the rear cassette, a 50 to a 52 will be under that. As Im sure you can see the bearing of the large chain ring on the front has little effect on top speed unless you are making huge steps. To drive a 52/11 on the flat you will have to be very fit and thats on the drops on a road bike. Descending hills is a different story, but not much. To the cassette, think of your drivetrain has having 2 gearboxes the large and small chainrings. The cassette is the ratios contained within that gearbox. A wide spread say a 11/27 (you can go higher than 27 but this would bring in added complications) will give you a greater range but the steps between gears will also be greater. A narrower spread will give you smoother gear changes and better acceleration for example an 11/23.
Chain ring choice becomes much more important when climbing.
jim55 very imformative but Im sure your comments reflect more on you than they do me![]()
Thank you. I think I will go for a 48/13 or a 48/11 maybe.
Also, I decided to keep my existing bicycle as well (I wouldn't be able to sell it for more than perhaps 50 quid...). If I have the present 42 replaced with a 48 will the bearing be okay with that? I guess there is a bigger force then, and not sure the construction is strong enough for that? Or maybe I should just leave the present bicycle alone...
