Zippy said:Dropped into cycle shop on way home. They measured the chain and found it to be well stretched beyond its useful life, though the block was ok. Both changed at the same time.
New chain bought - may sort the problem.
you said the problem got worse after you last fitted a new chain and block.?
How can the chain be that worn unless you forgot to tell us you've done 15000 miles since then
THanks for coming back to post the outcome.
