Cubist
Still wavin'
- Ovver 'thill
Adjusting the mech needs several variables checking. Firstly alignment. This is the "B" screw, and it adjusts vertical alignment of teh mech cage/jockeys
There needs to be clearance between teh bottom of the cog and the top of the jockey wheel with room for the chain to pass through without fouling. This takes a bit of trial and eror
But this looks about right. I'll recheck when it's on the big cog as well.
Cables next. This is the front shifter, and needs to be cabled up whilst at granny ring setting, so click off the lever to remove indexing tension. I'm going to remove the old cable
Wind the adjuster barrel all the way in then out a turn or so.
Remove eth rub screw from the cable entry
and don't lose it!
Push the old cable out of the shifter housing and remove.
3m of new outer to measure up and cut to length
When measuring cable outer make sure it's long enough to allow full bar rotation, but not too long to keep things neat and tidy
Outer cable throught the cable clamps on the top tube
through a cable tie on teh hose guide lug and measured to length in the cable stop on the front mech
and don't lose it!
