U
User169
Not legal in Belgium, apparently.
Yes, the group I cycle with tends to double up. It deters motorists trying to squeeze past and also shorten the distance required to pass. We single out when the road requires it.
No
Given that the vehicle ahead (i.e. the cyclist) has a better view of oncoming traffic and very likely a better sense of his own speed, I cannot think of any reason this decision would be better made by the motorist instead. Can you?Isnt it up to motorists to decide if its safe for them to overtake ?
Sensible.
Cyclists riding single file - seen to be fitting in with other traffic and everybody fitting in with everyone else as best they can.
Not the cycling militancy that prevails on this forum - were cyclists and we'll do what we want and f anyone else.
When does the road require you to single out ?
No, it means leave the same space between the car and vehicle it is passing
No, it really doesn't. Try looking at the picture that is provided to make this crystal clear to anyone. (I won't show it again as it's already in two posts in this topic.)
The picture is clear in my mind.
Replace the bicycle with a car and the passing car would be far too close to the passed car.
Therefore, the "room", "space" (whatever the HC says, cant be bothered to look it up) must mean space, gap.
We single out on narrow/back road to allow other faster traffic through. Where is the inconvenience in cyclists riding two abreast?
Yes . The motorist has a better understanding of what his car has the capacity to do than a cyclist in front.
In all instances, the best course of action is to wait until is it safe to pass. If that means sitting behind cyclist riding two abreast then so be it. When you're driving, do you immediately pull over when a car travelling faster than you approaches from the rear?
They go along roads and around corners and are probably capable of speeds in excess of any legal limit in the UK. Some of the less capable models have "indicator" lights at each corner which are used to signal the drivers intentions to other road users. They go better on tarmac than on ice or grass. They don't go up kerbs or over bollards very easily.Yes . The motorist has a better understanding of what his car has the capacity to do than a cyclist in front.
