MartinC
- Cheltenham
Sorry for the confusion. It may not get any better!
Jimbo's suggestion has some merit but it's always different strokes for different folks so it may not suit you. Your options are (in increasing order of cost):
If you've got a medium cage mech on the rear (don't worry about how you can tell - yet*) then the easiest and cheapest way to get a lower gear is to change to a 13-29 cassette. This will give you a bottom gear of 2.8 metres instead of 3.3 (assuming 700x23c tyres). This is a significant difference.
If your rear mech only has a short mech you can't do this (according to Mr Campagnolo - some might take the chance). So you could:
- Change the rear mech (for a medium cage one) and the cassette as above.
- Put a Mirage compact (50/34) chainset on the front. You might have to change the front mech as well. This is complicated - Campag front mechs have varied a bit over the last few years and there are questions about whether it's a standard or a compact mech and whether it needs to be a QS one. This would give you a bottom gear of 2.9 metres - again a worthwhile difference.
- Put a cheaper (FSA, Stronglight) compact chainset on. Effect as above but you'll need to change the Bottom Bracket (BB) too.
If you want to go to a triple you'll need to change the rear mech, front mech, chainset and BB. This will give you a good spread of gears and a bottom gear of 2.5 metres with you current cassette and 2.2 meters if you changed to a 13-29. You could climb Alps with this.
* Campag mechs come in short, long and medium. It refers to the length of the cage plates that hold the jockey wheels. Look at the Campag catalogues online (www.campagnolo.com) for pictures of different length mechs - you'll be able to tell the difference.
