ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
I just looked up the widths of different speed chains... The 8-speed chain I had fitted is about 1 mm wider than the 10-speed chain that the original donor cassettes were designed for. No wonder there is rubbing!
I have a new 10-speed chain. I'll put that on and either give my 8-speed chains to a mate to use on his singlespeed road bike, or keep them to use on my singlespeed turbo trainer bike. (If the latter, then they would probably outlast me because I barely use the turbo trainer now.)
There is some slack in the gear cable so I have to turn the shifter lever through about 30 degrees from its downmost position before it starts the shift off the 12 tooth sprocket. I'll do the bar tape first because I want to loosen the shifter body to tuck the tape in under it. Once that has been tidied, I will take up the slack in the cable. Oh yes - the shifter does pull enough cable for my 6 sprockets. I'm not sure that it would have been able to do a full 10-speed cassette rather than my edited highlights version though.
I'll get back to work on it once my brunch has gone down. The weather is not bad here today so it would be good to get a test ride in later. Rain is forecast for tomorrow...
) but I thought that the plastic label warning of a protective plastic film WAS itself the plastic film!
I don't know how long the mirror will last before I accidentally snap it off, or some idiot does it deliberately when I leave the bike locked up when shopping.
