MontyVeda
- Lancaster... the little city.
All the time!... I could just freewheel on the descents.
Have any of you ever done anything like this?
Two chainrings and two sprockets, each pair with the same total number of teeth.I am going to try doing one of those hilly loops on my best bike with the gear kept at 28/19, which is near enough equivalent to 42/29. If I like it, I will go ahead with the dinglespeed project.
I doubt that I will be able to use 28/17 but if I can, that would be equivalent to my next higher option - 42/26.Forget that - different chain lengths!
A 'dinglespeed' or 2 singlespeeds?
Hmm... I tried it but was surprised by how much slack there is in the chain in the 42/29. It is a lot more slack than I'd want to take up with the chain tensioner. It might work with a 43 or 44 tooth ring but I am not going to buy an expensive new Campagnolo chainring to find out.
If the bike had horizontal dropouts I would be able to take up the slack without using a tensioner. Maybe one day I will buy a suitable new frame and do it properly!
In the mean time... To simulate overgeared dinglespeed climbing, I will try to do those climbs without changing from the 36/24 gear on my best bike. That is around a 40" gear. (And I can use a sensible gear for the other parts of the rides.)
IF you have horizontal dropouts...Using multiple sets of chainrings/sprockets with the same chain length, but with the same tooth count or one tooth difference does work.![]()
I had another look. The chain does have quite a lot of slack and I don't like how much chain deflection the tensioner is having to impose, but it does actually just work.I'm surprised it doesn't work
Well done, that's a very creative solution.
I'm presuming that you are using standard Shimano type sprockets removed from a cassette, with a standard hyperglide hub.
If so, as you already probably know, a 30T sprocket would probably work too.
Maybe, someone has a spare used 30T cassette, so you can remove the 30T sprocket by drilling the rivets.![]()
What you need now is a derailleur to replace the chain tensioner, and while your at it a front derailleur and a couple of down tube shifters, would be a good idea.
You can still just use the 2 gears with derailleurs, just stops the messing about changing by hand.
