Yellow Saddle
- Loch side.
Some people seem to think that local changes in spoke tension cause changes elsewhere in the wheel. It doesn't work like that. The typical notion is that if you look at a wheel head-on and consider it as a clockface, any change made at 12 o'clock (say tightening the spokes) will have an effect at 6 o'clock, the spot directly opposite. Novices struggle with this but it is wrong and misleading to suggest it.
A local change remains local. If there is a bump at 12 'clock and you tighten the spokes at 12 o'clock to flatten the bump, only that region changes. Nothing else is affected.
When teaching people to build wheels I often came across this problem and one way I tried to instill the concept is to get them to look at a car's wheel on a parked car. The car's weight causes the tyre to bulge at the bottom only. It doesn't cause some sort of stretch at the opposite end. The implication of this is that the hub always remains the centre of the wheel and any force acting on the wheel only acts between that spot on the periphery and, the hub itself. This is analogous to spoke tension. The car's weight bulging the tyre at the bottom is no different from spoke tension pulling the rim inwards.
