- Glasgow
Hi Binka, I got Marathon Plus too. On fitting them for the first time I broke 3 tyre leavers, almost broke digits, took me over 2 hours. Got a pinch flat next day (my fault for pinching the inner tube), fortunately not far from work, changed tube after work: took me an hour!Thanks, will try not using tyre levers to put the tyre back on next time. Ive got marathon plus tyres which I've read are hard to get on and off.
The good thing about Marathons is that if you keep them properly inflated, check routinely for embedded sharp debris, you should not get punctures.
It is true they get easier to fit with use, the rubber becomes softer.
