malcermie
- Dover, Kemt
Ok I shall be a guinea pig!!!! Will get some on Monday and take the recommended dose for a month and report back, unless I turn into dog, guinea pig or hamster
Inflammation is a response to a stimulus (ie: burns,chemicals,physical injury(like a knee!) which is there to protect the area and allow healing.
Or see a doctor, maybe try to find an underlying cause?Ok I shall be a guinea pig!!!! Will get some on Monday and take the recommended dose for a month and report back, unless I turn into dog, guinea pig or hamster![]()
Better still put the oil into a pan and fry chips in it!Why not take a teaspoonful of sunflower oil every day, even cheaper and just as effective as a placebo perhaps? Before condemning that idea, just test it?
They should be aware of the basics of joints, perhaps not in relation to cycling. But at the very least, a GP who knows your full medical history is in a better place to advise than the CC massif would ever be. Unless you happen to have a doctor who is a connoisseur of sport like mineGPs aren't very good at this sort of thing though, are they? An orthopaedic surgeon will want to operate, and a physio will prescribe exercises. But here the easiest route would seem to be a tweak of the bike first.
Our 4 legged friends are often victims of joint issues we as humans have no cure for. At best life can be made more comfortable or indeed ended in the case of fallen horses. I do believe though, horses are being used as trial subjects for some localized injection method. I can't remember offhand what the process was called but it was basically, fluid from one joint injected into another type thing.I do take your point about inflammation though. I've only come across this in relation to horses so it might not be directly applicable. But there, anti-inflammatories are prescribed on a very long-term, and sometimes permanent, basis as if no healing would be expected to take place. We were also sometimes told to encourage inflammation by using heat (and there used to be a rather barbaric practice called 'firing' in which tendons were seared with a red-hot iron for this purpose).
A lot of the remedies are a comfort issue over repair though. Some interesting reading if you wishPeople use these remedies for aching joints on a very long-term basis, when it might be expected that a joint would protect itself eventually with calcification (have I got that right?) and the inflammation would die down.
I was told that by someone once so I thought I'd try it. I managed to get all the oil down before the shock hit me! I was doing fishy burps for the rest of the day - not nice!Cod Liver Oil Works - if (IF?!) you're man/woman enough to take it correctly.
1 - Use it in liquid form - not capsules.
2 - Mix a tablespoon full with half a glass of cold milk and drink it first thing every morning, before drinking or eating anything else.
3 - Eat nothing and drink nothing for 30 minutes.
I don't know whether my joints ached that day - I was too busy trying not to throw up!I was told that by someone once so I thought I'd try it. I managed to get all the oil down before the shock hit me! I was doing fishy burps for the rest of the day - not nice!![]()
If you started taking it 20 years ago you might not be suffering now.![]()
Have a curry! (You don't need to buy high fat ones made by someone else - cook a healthy one yourself.)The turmeric thing sounds interesting but how would you incorporate it into your daily diet? (assuming you don't eat beans every day)![]()
