Rigid Raider said:
Car waxes contain a fine abrasive, which polishes the paint and removes surface dirt. After that the solvent dries off and leaves that chalky deposit, which also contains the wax.
I polished my safety googles with car wax; they were all scratched and manky but they came us like new with some vigorous rubbing. Did the same with the plastic "glass" on my son's Swatch, which got scratched. Rubbed it flat with wet and dry, polished with Brasso, which is quite abrasive, then finished with car wax and for 10 minutes Dad was very popular!
On a bike frame the wax causes water droplets to bead and run off rather than wetting the surface, which helps with subsequent cleaning and helps prevent rusting where the paint is chipped.
Yes some car polishes/waxes do contain abrasives, these are classed as an all in one treatment, OK at many jobs just not ideal/perfect for any particular one (jack of all trades master of none) but also as the OP asked about carnauba these all in ones contain less than 2% carnauba at best
fossyant said:
I was talking the Carnuba wax bars - I have polish with the stuff in, but the 'car detailers' will use the bars and some water to pull crap off..then use the polishes.
Just good car polish is fine, or Mr Sheen...
Pure carnauba bars will not work at all, as per my first post, its as hard as rock and will cause damage before giving any type of protection, trust me I earn a very good living using these products, I don't know everything and I'm still learning but if I am given almost all of the best super cars about to look after I must be doing something right.
The bars you talk about with using water is not carnauba but whats called a clay bar, its used to remove all surface containments, the water is used as a lube or the clay will impart marring to the paintwork. And yes the paint is then polished to a perfect or as close to perfect as is possible, normally using machine polishers of different types and also a multitude of foam pads, abrasive polishes and then cleansers.
Nowt wrong with a quick wipe over with Mr Sheen, though try using it on a black car in sun light as try to buff off all the silicon smears, but for a bike its ok
User3094 said:
I use this stuff which I think has got Canuba in it...
http://www.autoglym.com/enGB/product-proddetail.asp?v06VQ=HJ&Range=1
Smells nice anyway!
LOL, yep smells nice and also contains a suspension of carnauba, though when I spoke to the AG rep at a trade show he wouldn't be nailed down on the exact %. But what works and makes people happy is good for me, plus AG is aimed at the every day guy not the perfectionist.
