fossyant said:
It's used to take out/off stubborn dirt/imperfections - leaves a smooth surface for polish to be applied. Not likely to be that useful on a bike, as they generally don't live outdoors and need this !
Sorry the first part is way off the mark, Carnauba does not take out/off stubborn dirt etc it is by its nature only a protection. If you want to remove stuff then you first need to use a cleanser with has either chemical or mechanical cleaning properties.
Sorry a bike does need protection, well that is if you intend riding it outside, maybe not as much as a car but why let the elements do damage to your pride and joy?
Carnabua wax will protect any finish, paint, carbon, metal and even rubber but there are many many different grades of carnauba. Carnauba in its pure form is a solid unusable material, it has to be mixed with other items to make is usable. Cheaper waxes will at best only contain upto 3% carnabua the rest will be anything including heavy solvents like petrol. Mid range waxes will have upto 30% carnabua, next to no solvents and then the top stuff will have anywhere upto 75% carnauba and nothing harmful added. In fact the best stuff can be eaten safely.
Good quality carnauba when applied and allowed to dry, buffed off and then polished will actually have a harder surface than concrete, though it won't stop stone chipping paintwork. However its real gain is when you need to wash, a hose spray will remove almost all dirt, even off road dirt, leaving only a small amount that will need wiping off or at worst shampooing, then drying it to leave a like new look.
The better the quality of wax the longer time between coats needed to be applied, some of the best wax will only need 1 coat a year, even with washing 2 or 3 times a week, though this is dependant on how you wash it plus the amount of shampoo used. If you have a look at my Scott in the gallery it has 4 coats of wax on it, ok the wax is super expensive, costing more than my zipps but in theroy it won't need another coat for 5+ years, but as I use this wax on a reg basis for my business I have some
Not that I know anything about cleaning and protecting motors and bikes
![Evil :evil: :evil:](/styles/default/xenforo/smls/diablo.gif)
