Doe my cassette look worn?
nmfeb70
Tonypandy, Wales
Hi all, I fitted a new chain to my Trek MTB yesterday and it started skipping in the highest gear/smallest sprocket. Thinking it was too long (even though I sized it up against the old chain) I took one, then two, then finally three links out and the problem still persisted, the chain was then too short (Doh!). I have put the old chain back on the bike and everything is fine. I know what you're now thinking - a worn cassette is the problem - but the cassette looks fine to me?
I've attached a photo, albeit the sprocket in question is a little difficult to see.
I will add that I am meticulous when it comes to cleaning the chain and I replace it as soon as it borders on 75% worn. The cassette has been through three chains. Thanks.
If the cassette has done three chains you've had your moneys worth. My commuter gets chainring, chain and cassette changed every 12 months
C R
Worcester
If it's only skipping in the highest gear then might be worth tweaking the limit screws on the derailleur to see if that helps
The chain will skip in the most often used cogs of a worn cassette. For most people those would be in the middle of the cassette, but maybe the OP uses the smallest cog often, and having a small number of teeth that will wear more quickly. Normally you don't see limit screws needing adjustment if the derailleur has been properly set up, and changing a chain should not affect the derailleur set up.
Dogtrousers
Kilometre nibbler
I've read on here, from people who claim to know what they are on about, that, unlike chainrings, it's not possible to detect wear on a cassette by visual inspection. That may or may not be true.
I use the test that you're using: If it skips on a new chain it's worn. If it doesn't it isn't.
wafter
Oxford
Can't tell from the pic, but as others have said 3x chains (all to 0.75% wear, too) sounds like the cassette's given good service and conforms to the (legit or otherwise) adage of 3 chains to one cassette..
Or finding a cassette to donate the worn gear.
Indeed; if you want to be really tight you can usually buy the smaller ones new; would be interesting to fit one and see how long the rest of it lasts.
I like Skol
A Minging Manc...
You can't usually tell if a cassette is worn just by looking at it.
Maybe it's just me, but apart from the largest sprocket and the smallest one that is mostly obscured, that cassette looks to be clearly well worn with an obvious deformation of the teeth at the pressure point! Defo need to bin the whole cassette, shame you ruined a good chain.
