youngoldbloke
It's easy. To remove a link when fitting a chain, or in an emergency on the road, use a chain tool; to join or rejoin a chain use a quicklink.
You mean pushed through?Also, it is unlikely that a peened pin can be used again after being pushed out.
I assembled my last and currently mounted chain from a part of a new complete chain and remainders of 3 earlier chains, as to be eco friendly (grin). So I had to hammer 3 pins back into holes, AND I used the new quicklink so that I can remove the chain easier when needed. Best of both worlds.It's easy. To remove a link when fitting a chain, or in an emergency on the road, use a chain tool; to join or rejoin a chain use a quicklink.
I thought this was a good analysis.the shape of their metal surfaces is designed to match each other so that no metal is deformed beyond its elastic region.
A thin roller chain link plate, does not match the rivets, and gets deformed beyond it, leaving a weaker connection.
@silva - You say: "Of course a peened pin can be used again after being pushed through." Do you mean you think a peened pin can be used again successfully, disagreeing with @C R ?@C R said: "it is unlikely that a peened pin can be used again after being pushed out." You mean pushed through?
Of course it can, deforming the rivets back towards the pin like it was before requires big hammer blows while a chain tool just pushes gradually, allowing metal to deform plastically.
The link plate is the eventual permanent deforming part of the story.
Hollow pins are a different story due to embedded inside the link plate instead of protruding outside it, a 50 50 story and less material so case hardened without elastic material backing it up, either side "loses", that is, permanently deform, even both, a weakened connection, or no connection at all, is virtually guaranteed.
See the chain at the right side of the picture.I thought this was a good analysis.
Have you joined many 11sp chains? I thought you were an 1/8" chain aficionado. Have you joined, both successfully and unsuccessfully chains with "hollow pins"? Just asking. Or is this just theoretical?
So did I, so I searched on ebay and found a company selling multipacks of no-name links for not-a-lot! (I have lost the details of exactly what I bought, but it was something like THIS - 5 links for £3.04, including delivery from China!) They took about a month to arrive. I thought that they might be cheap and nasty but they seem to be pretty good - I haven't had one fail!I resent paying £5 for 1 link
Yeah I bought something similar but just 2 pack not 5. They look ok but not had to use one yet. I've seen thoseSo did I, so I searched on ebay and found a company selling multipacks of no-name links for not-a-lot! (I have lost the details of exactly what I bought, but it was something like THIS - 5 links for £3.04, including delivery from China!) They took about a month to arrive. I thought that they might be cheap and nasty but they seem to be pretty good - I haven't had one fail!
Let's face it - for that kind of price, it isn't much of a risk, providing you don't have one snap when standing up and sprinting...![]()
It was a slipped chain rather than a snapped one, but my extremely painful and gory teen cycling accident confirmed that!You really don't want your chain snapping when out of the sadle that's for sure.
Every link in the top part of the chain has the full force acting through it and passing it to the next one. The ones in the bottom section of chain have very little tension on them. Obviously the chain moves round so all links get the full load and minimal load repeatedly.We've all heard the
saying 'a chain is only as strong as its weakest link' but how does a chain cope with the stresses involved?
Is the main (max) load spread over all the area of the chain that is between the chainring and the rear
sprocket? Therefore each link would take a percentage of the pressure, similar but not exactly like a house
brick in a wall? Idk
That might be different for a fixed gear bike...?Every link in the top part of the chain has the full force acting through it and passing it to the next one. The ones in the bottom section of chain have very little tension on them. Obviously the chain moves round so all links get the full load and minimal load repeatedly.
Both of my failed links were on branded chains (SRAM) and the 7 or 8 broken chains that I have repaired for other riders probably were too.One really wants to mitigate any risk that a chain will fail on you. If a rider is not competent joining a chain, use a branded quick link correct for the chain 'speed'. Do you use cheap brakes blocks/pads to save money?
Please ensure that your executor/dear friend / relative has your CycleChat login details, @ColinJ so they can let us know when there's been a problem at the end of a descent, of the 'tis 'ard oop north' variety, with cheap brake blocks on the front.As for buying cheap brake spares... ALWAYS!! I have been very hard up for years so I bought what I could afford. No problems with those at all, and I use them on steep Yorkshire/Lancashire descents at speeds exceeding 80 kph (50 mph)!![]()
I might have mislead you... I don't buy unbranded brake blocks/pads, just not big name branded!Off topic
Rim brake blocks (expensive at £11 a pair) last 11,000km so that's 0.1p per km. One pint of beer = 4000km.
Though perhaps you have disc brakes for those rides with wicked descents, with cheap pads.
Blimey - I just checked - the price has gone up A LOT since then!What? A right load of B***LOCKS ...!
PS There are 2 different types there. One type for the 9-speed Campag on my Basso, the other for the 10-speed Campag on my Cannondale. I bought so many because Discobrakes do a very special offer on 4 pairs, and it is always good to keep spares. In fact, a mate has already bought 2 pairs from me. (No - I did NOT sell them at a profit ... I actually lost about 4p on the deal!)
4 pairs for just under £30 still isn't too bad though, especially since I now have a little more money coming in from my pensions.
