Shooter999
Thanks everyone. All advice really appreciated.
Correct.Not directly but if not all the teeth are making good contact, the force is applied through fewer links so there's a higher peak out-of-line force in each link as it passes and that's why it wears faster, isn't it?
On modern chainsets like the OP but not vintage?
sorry, i am not techie but can confidently state that this is not true. I have a bike i don't live with and will soon be fitting a new chainring to (single chainring linked to 7 speed cassette mounted on 3 speed hub gear) for it is slipping like mad. My ridgeback hybrid/tourer 3×8 was recently slipping like mad. If your statement is true how do you explain the fact that a swap of the middle alivio front chainring immediately solved the problem? I am still puzzled by how that chainring wore so quickly but the swap definitely sorted things.Chains don't skip on chainrings, only on sprockets (at the rear).e.
I'll call it skating, thank you.skating, skipping, whatever you want to call it.
Bear in mind the teeth are meant to be different shapes to aid shifting.
Some are more pointy than others and it's easy to mistake that for wear.
