Personally I would say no. The softer the seat the more comfy it may appear when you first sit on it, but it becomes painful for longer rides. Conversely, a firm seat seems hard at first but I find on a long ride you stop noticing it as it is supporting you rather than digging into places that the gel eventually does.Anyone? Like my sportives and long rides and wondered if they actually do make a difference. Asked the folks in my group and most felt that it was not necessary.
I'd agree that a soft thick gel saddle isn't a good choice for longer rides unless you're either really upright or need it for some other reason.Horrible things!
After quite a few saddles, I finally found one that works for me (a Bontrager MTB saddle) but everyone is different, although I think most agree that a soft gel saddle isn't good for anything other than short leisure rides.
That's the Charge Knife which Charge say has "foam padding"... or in other words, probably a gel. So does it make you sweat and create sore spots?Ghastly things; they make you sweaty, which creates sore spots. ... my Charge Knife is super-comfy even over 100 miles - I just don't notice it.
A seat that would be measured for your seat bones and fitted correctly would be the best way forward topped with a good pair of bibs with a good pad
That's the Charge Knife which Charge say has "foam padding"... or in other words, probably a gel. So does it make you sweat and create sore spots?![]()
So they've all been open foams rather than any being a closed-cell foam (aka gel)? Seems surprising, given what's on sale.Not a gel. I've stripped and re-covered several of these modern plastic saddles and it's a dense foam cleverly moulded onto the flexible shell, then covered in a perforated vinyl.
