Globalti
I installed a solar panel on my roof a month ago and it's working fine, it even picks up a bit of heat when the sun is out. However I've been looking at the pipework in the attic and have had several small insights into how it could have been better. I admit that when I first did the installation I was working from nothing and with no experience but now I've decided to take some of the pipework apart and redo it; luckily everything is done with compression fittings so it won't take long. The new layout will be more efficient, with much less liquid in the pipes and a shorter route from panel to coil. It will also look less amateurish.
Have you ever done this? I guess when companies do this it's called research and development!
