spandex
I love Dr D
just go to your local diy store they will have one.
bonj said:the tell-tale sign of a quality tradesman - the slagging off of shoddier work by those who have gone before![]()
Smokin Joe said:Mickle,
The plastic screw conectors on the water hoses always say do not overtighten, and are obviously meant to be done up by hand. Do plumbers ever get fed up with trying to fit the things so they don't leak and use a fecking great mole grip like I did?
bonj said:i had to use a mole wrench to un-plump my mum's dishwasher when she moved house.
(There's nothing like a wench to help get the weight off!)
trustysteed said:don't forget to put some of that white tape stuff on the threads of the pipes before you screw the new blue and red connectors back on!
Peyote said:PTFE tape, and make sure it's wrapped the right way round the threads. the amount of times I've wrapped it the wrong way only to see it unravel as I tighten the nut up... ...I gave up in the end and used Boss White Pipe Jointing Compund!
mickle said:Wrong old chum, PTFE tape is not used in this application.
bonj said:and messing with gas pipes is illegal unless you're corgi registered.
spandex said:your right thats for gas fittings not water!!!!
spandex said:sorry bonj but
c.o.r.g.i is the council for registered gas installers like the guild of master craftsman they just set the standard to work from. Like say cytec is the one for bike mechanics it dose not mean that no one can do work on a bike untill they have payed the £1000 and done the course!!!. But with gas it is best to leave it to some one that is corgi registered if you dont know what your doing.
