02GF74
Cubist said:Disc brakes are, IMHO the only option if you're riding in wet or muddy conditions.
In other words, if you live in UK.
I get the impression some people use their brakes much more than others which perhaps accounts for the difference. People's definitions of when a rim is worn out are also quite variable.col said:Iv never had a rim wear problem with blocks, and dont get what the difference would be other than slightly easier to pull the levers.Well set up blocks do the same job dont they, the wheel will lock up at the same point of braking with both.And one finger braking with blocks is just as easy.
GilesM said:Try a bike with good quality well set up hydraulic disc brakes, and try it on some good descents, you'll soon see the benefit.
But they don't col, that's the thing. I happen to like light, short-travel hard tails. Even a set of the finest linear-pull brakes on ceramic rims can't haul you up as quick as a middle of the range disc such as Giant's MPH. But then a short travel HT isn't going to be coming off the mountain with the same urgency as a long travel bike. It's horses for courses.col said:Im not pulling disks down, and I dont doubt a good set is going to show a difference in some way, but the extra price for how much difference, is it really worth it when blocks can stop you as quick ?
SilverSurfer said:Can't decide whther to go for hydraulic discs or just plump for good, ol fashioned V brakes.
I had a bike with hydraulic discs and initially thought they were great. Then I realised that they would need to be serviced at some point and I realised that I didn't kow how to do that. Bleeding brake fluid and changing pads seems like car servicing to me.
So I'm starting to think that for my type of riding (cross country trails, nothing technical) that Vs would be a more sensible choice.
The only downside that I can see to Vs is that they will wear through more rims - is this the only consideration?
