llllllll
Bit new to disc brakes, so I hope this isn't too stupid a set of questions. I've got a cheap cable disc (avid something or other) on the front of a chopper, it get's very little use - probably only about 50 miles since new, but the rotor is already warped. Do they warp like car brakes because they get too hot too quickly or is it just a cheap nasty part? Is it possible to true the rotor or does it need replacing and will a more expensive model not warp so easily - any recomendations. Is it possible to fit a bigger rotor or will I need to change the caliper as well?
Thanks in advance
Thanks in advance
