ian emmerson
My rear brake is continually rubbbing against the disc and although it doesnt appear to be causing any fiction.
I have checked the pads and given them a light rub with fine sandpaper, cleaned the caliper etc. I have also re aligned the brake by holding the brake lever whilst tightening the caliper without success.
The disc appears fine with no buckle etc.
I have noticed what appears to be an adjusting screw but unsure if this would help without knowing for sure and as this screw also has what appears to be a "star" type washer.
They are shimano disc / brakes on a scott hybrid if any help.
Thank you in advance for any suggesions
Ian
Ian
