Disc brake maintenance?
MattDB
I've gone from a road bike to a mountain bike. I'm on an entry level machine but loving it, particularly loving the disc brakes and their performance in wet weather.
With my road bike it was a simple matter of cleaning the wheel rims and then using a cloth to make sure there wasn't any grit stuck in the pads and (carefully) putting a drop of oil on the moving parts.
I've been told that I need to keep disc brakes clean to avoid problems (and squeaking) but just wondering what people do to maintain theirs?
dodgy
Soap and water and from time give the discs a vigorous rub with a clean cloth with some IPA (Isopropy Alcohol).
lpretro1
Bleeding should only need to be done when there is air in the system not as routine maintenance - or in the case of a brake system with DOT fluid in it every 2-3 years. Ham-fisted or incorrect bleeding causes more problems than it cures (see many old posts on this forum!).
