Business cards, how analogueCereal packet is a bit blue collar, I used left over business cards 🤣
I use a bit of Rizla packet.![]()
Only works with new points though or ones that have been 'filed' flat, once they're a bit pitted they tend to grip the paper for a while after they've opened.Blimey! Thats a blast from the past, setting the points with a Rizla fag paper.
I haven't been able to find a specified clearance (likely it varies between models) - anyone know?
Satisfactory clearance will also depend on trueness of the disc.
I found advice that a 0.2mm feeler gauge was 'about right'. That's 8 thou.
I think the tool is to set the disc centrally in the caliper.Excuse me for being a bit dim here, but I thought disc brakes were self aligning?
Obviously the above procedure is for hydraulic discs, so what's with this gizmo, is it a vital step I'm missing out on? Or is it for cable pulled discs?
some of the one sided adjustment cable disc brakes needed a business card to set them up, i used to do on some Avid BB7s back in the day.Excuse me for being a bit dim here, but I thought disc brakes were self aligning?
When I pop new pads in I just need to gently ease the pistons back, then pop in the new pads. Pumping the lever a few times, then bedding in the pads sorts everything out and all's well with the world.
