"ding dong" bell
Joe24 said:
Where do you keep them all? In a draw, on a bar? Just sitting on a shelf?
Do you get them out every so often, ring them slightly to check they still work, smile, then hide them back away?
Yes. And the spare ones I keep on bicycle handlebars.
bonj said:
you mean flawed :ohmy:
phones' limitation is that they only transmit up to 4kHz, whereas the human ear can hear from ~20Hz - 20kHz., but 4kHz is actually quite high pitched. even 1kHz is fairly high pitched. To give a comparison, most speech is 80Hz - 450Hz. If what you require from a bell is that it has excellent sound quality in the above 4kHz range then you probably need to be visiting a specialist bell manufacturer in person.
Alternatively you could use one of those things that really annoys teenagers but that people over 30 can't hear :biggrin:
woo!
go bonj1
