rb58
Enigma
- Bexley, Kent
I'm a reasonably quick descender I think (that'll be a mass/gravity thing!) and I've passed you (Martin) on downhills a few times. Having seen how you go, I'd say it's 90% a confidence problem, 10% technique. So, my advice would be to follow someone else to see the lines they use and how they regulate speed before the corner (not through the corner), building it again on the way out. And try the same descent a few times in quick succession to boost confidence. Up and down Toys Hill north side would do it. Also, pressing down on the outside pedal really does work. With respect to gravel, I've learned that you can't fight it so no sudden direction changes whilst on it, and it's best to let the front wheel find its own way, then correct as best you can after you're clear. That way you at least stand some chance of not hitting the deck. And as Moodyman says above, sit well back in the saddle, but keep your weight over the pedals. That'll help keep the rear wheel planted on the road.
