On the turbo bike I have a Shimano 105 10 speed ss well used rear derailleur matched with 105 5700 10 speed shifters, I have to use a goat link on this frame to use a 32t largest sprocket, it doesn't give the smoothest of shifting, I have a Tiagra 10 speed 4700 gs rear derailleur that would clear the 32t sprocket without the need for a goat link, but the activation ratio is 1.4 the 105 is 1.7, has anybody successfully run the combination of 10 speed 105 5700 shifters with a 10 speed Tiagra 4700 rear derailleur ? if so how?
A Jtec shift mate looks an option, although that combination is not listed but looking at the numbers Jtec 3 or 4 might work.
The cable pull of the 10 speed 105 shifters is 2.32mm the sprocket spacing of the 10 speed cassette is 2,95mm and the activation ratio is 1.7
so 2.32 x 1.7 = 3.944
The Tiagra has a 1.4 ratio
so 2.32 x 1.4 = 3.248
The Tiagra needs 0.7mm more pull per click to work correctly.
Any thoughts ?
Any thoughts ?
