Alex321
- South Wales
But it's the shifter that determines the pull ratio isn't it?
Not by itself. It is a combination of shifter and mech.
The shifter determines how much cable is pulled for each gear shift.
The mech then moves a specific distance for that amount of cable (the pull ratio).
That distance must match the distance between sprockets. If you have shifters expecting one pull ratio, and mech expecting a different one (or if both of those are the same but the cassette spacing doesn't match), then you will not be changing cleanly one gear for each index position.
