Ming the Merciless
There is no mercy
- Inside my skull
I said that in one line... 👅 It will work one end, not the other....
Except you didn’t you said “It won’t work” 🤪
Stick it up your 42 👅👅👅👅
Won’t fit 😘
You'd be doing VERY well to walk a bike up a 25% ramp at 3 mph!I'd be walking up at 3mph........
I do because I bought one soon afterwards! I haven't fitted it yet because the bike it is going onto needs a new fork.Anyway, do you remember I fitted and rode one of these 42T rear sprockets a good few years back, but with a 34T front chainring.
No there isn't: because this is a ludicrous combination.there must be an off the shelf rear derailleur option
That is a single chainring set up. Your proposal is a triple adding a further 20T diff into the mix, which is why is won't work.The Hope Eagle has a 30T front and a 52T rear using SRAM, that's a 15 inch gear, the same as 24T - 42T.
You are probably correct, but as you know MTB's have used 26t front with 10-50 rear. Yes, a triple exceeds the capacity, so restricts ring combinations.
I've cycled up a few short 20% climbs last week, so I don't need an ebike at the moment, but, yes in the future I will.
Read this, if you don't believe me about 26t front with 10-50 rear on a MTB, but I know, you know this.
https://www.mtbr.com/threads/running-a-26t-front-with-10-50-rear.1085725/
I've got a 24T-34T-44T front triple and I have a 42T rear sprocket I would like to use.
down tube friction shifters.
But, what rear derailleur would work?
You asked what RD would work (triple + 11-42): the answer is 'none'. Who's saying we "don't believe" you about a 1x combined with a huge range cassette? This seems to be your strawman.if you don't believe me about 26t front with 10-50 rear on a MTB, but I know, you know this.
