DELETED
Ian H
Ancient randonneur
You might as well use your 24" gear. It's foolproof and doesn't wear the chain out.
All uphill
Still rolling along
Somerset
I've got a 30 chainring and a 40 at the back and a sora rd with an extender from Spa works fine.
I'm shocked how often I use that lowest gear and wouldn't mind a 42 when it's time to change cassette!
T4tomo
Assuming its 11-42 then you need a capacity of 51 teeth. which you wont find. Even the new deore, set up for massive rear sprockets, only accept 41T diff and a max front diff of 10T if running a double
2nd point: WHY? Just why?
are you towing a caravan?
11-42 is generally for use with a single ring. 24-42 is a stupidly low gear, you'll be going so slow, even at high cadence, you'll probably fall off.
Twilkes
You're not kidding, 24/42 is almost half the speed of a 34/32 at the same cadence, 4.5 mph at 100rpm.
presta
Edit: I've just ordered a gold RD extender to match the gold 42T sprocket, I have two 42T sprockets in gold.
Edit: And two matching gold jockey wheels............................nice.
It doesn't matter what colour they are, you're problem is that the total capacity of the derailleur won't accommodate a chainring difference plus sprocket difference as high as 51 teeth. The extender increases the size of the largest sprocket it will accommodate, it doesn't increase the total capacity.
Ming the Merciless
There is no mercy
Inside my skull
I doubt it would work with your triple - you'll struggle with any mech and chain length to cope.
It’d work but they’d be certain combinations that would break the derailleur and likely chain. It can handle 44 front / 24 rear, 24 front / 42 rear you’ve got pretty much same take up. You just can’t have 44 front / 42 rear as things would break very rapidly possibly followed by the rider breaking as they hit the ground.
Thus while you’ve exceeded its capacity (most long cage rear capacities are around 42-45t capacity), that’s just means it doesn’t have the capacity to handle the full range of cog combinations.
Tigerbiten
On a recumbent trike you tend to push derailleur right to limit of their capacity.
So I've run a 9 speed derailleur setup with a 51t difference on mine in the past, 48-34-22 front and 9-34 back.
You must make sure it will safely run big-big just in case you shift into that combo by mistake.
If you cannot then things will break if you do shift to that combo by mistake.
Then just accept that you may not be able to use the smallest sprockets when on the small ring due to either the chain going to slack or it rubbing on itself due to how wrapped up he rear derailleur is.
Luck ............ :biggrin:
I said that in one line... 👅 It will work one end, not the other....
