Can't you just "measure" the wear by looking at the chain tensioner position?
It is surprising how quickly the wear happens. This picture shows a new chain and one that had only done a few hundred km!Can't you just "measure" the wear by looking at the chain tensioner position?
But you are the mighty and powerful @ColinJ , the trasher of bike transmissions. Us lesser mortals will get thousands of KM’s out of a chainIt is surprising how quickly the wear happens. This picture shows a new chain and one that had only done a few hundred km!
.That's because chain on top picture is clearly overtensioned. Even 428 motorcycle chain would wear in no time when tensioned like a guitar string.It is surprising how quickly the wear happens. This picture shows a new chain and one that had only done a few hundred km!
The chain actually wasn't quite as tight as it looks there. I've had a look back in my photos and found another one taken a few seconds later. You can see that there is actually a few mm of droop in the top run of chain...That's because chain on top picture is clearly overtensioned. Even 428 motorcycle chain would wear in no time when tensioned like a guitar string.
The roller diameters for single and derailleurs should be the same.Well, maybe, due to the roller diameter being 5/16" for 1/8" single speed chains and 3/16" for 3/32" derailleur chains, the chain checker tool wouldn't be as accurate, maybe out by 2/16", but that's still good enough for me.![]()
Last time I checked chain wraps around 180⁰ of the chainring -> wear is equal across all teeth.Also for chainring: the teeth perpendicular to the crank arms wear more because peak force is applied in horizontal crank arm positions.
So rotate it 90 degrees on its mount, with 4-5 chainring bolts, 1.
Only when the chain hasn't worn. Once the chain is slightly longer only a few teeth are fully engaging at any time and the force acting on the chain is not constant through a complete cycle of the cranks therefore some teeth have more force applied to them than others.Last time I checked chain wraps around 180⁰ of the chainring -> wear is equal across all teeth.
Yes, we use the term stretching, but we all know it really is the metal wearing. The metal between the rivets and the bushes wears first.
how the fantastic mr. fox can a chain be pre-stretched. That is just utter marketing cobblers.The RK415 is also pre-stretched, which might be helpful.
https://www.xlmoto.co.uk/mc-parts/c...s-415-630_c155/rk-415hsb-chain_pid-PM-4907102
Quote: "All 415H chains are pre-stressed and pre-stretched for superior performance and to minimise lengthening of the chain during its life."
A cyclist doesn't put a constant torque alike a motor.Last time I checked chain wraps around 180⁰ of the chainring -> wear is equal across all teeth.
Yes I know, but doing that is destroying the link, I need 106 links, the Regina 420's I found for sale at the best price were much longer so I plan to hammer one together with the unused remainders.You can split that quite easily, grind the rivets flush and use a dispensable screwdriver/ chisel to ping the plate off.
The Shimano Ebike chain may have been a better choice?.
