Decent light to mount on headtube
Tyke
Maybe get a bar extender suggested above and move the Cateye onto it with the light and freeing up a place to mount it.
Edge705
If you just want to be seen look at something like the leyzene mini drive its very light and small yet quite powerful
I understand your frustration with the cross levers I got rid of mine on the cylocross for the same reason (no where to mount anything)
Incidentaly I mount my front light at the end of the stem (where the bars clamp) I use plastic cable ties to secure the mount the light itself is releasable. The leyzene mini drive does not use a fiddly clip or pressy thing its mount is a sleeve so its easily removed and replaced. What's more its usb so can be charged anywhere there is a usb source but even so will last for hours between charges depending on the setting.
Well I am keeping the cross levers, having failed several times recently to effectively stop the bike with the tiagra brakes! They are either in need of attention or just useless!
downfader
extimus uero philosophus
'ampsheeeer
Cross levers? Yeah dont stop the bike with those, brake off the hoods or drops (presuming thats what you're talking about)
Precisely as I can't get the bike to stop effectively from the hoods on the giant. SRAM on the other bike is better... Fortunately as I have no choice!
Kestevan
Last of the Summer Winos
Holmfirth.
Looks the same - only difference I can see is the mounting. The Serfas unit has a pair of heavy duty rubber O rings which fasten round lugs at either end of the light.
I've had mine round the seat tube, and a rear seat stay with no problems, the light is held securly in place in both cases.
Deleted member 20519
Can it be mounded so it points vertical instead of horizontal?
Kestevan
Holmfirth.
Yes, I've had it both ways, in fact the vertical mounting is probably more secure. I've currently got the rear one mounted vertically on my seatpost. I've also mounted it horizontally on a rack, and vertical on a seatstay, no problems with either.
I've even tried mounting it verticaly on the headtube underneath the bars (obviously mines a rear light so I wouldnt run like this) and it looks perfectly secure. My only issue with this would be that the light then points straight in front rather than being angled down towards the road..... a small wedge under the top oring mount would probably correct this though.
In fact I'm now seriously considering this setup for a second light (in addition to a Vision 1) as I can see this being a really neat setup for a close "flood" light which would compliment the hopes more focussed beam pattern nicely.
