Damaged Spoke Nipple Trying To True Wheel?
Cletus Van Damme
Previously known as Cheesney Hawks
Today I tried to true the rear wheel on my Secteur Sport as it had went well out of true and one spoke was very slack after 200 miles. I did a search on here and tried some great instructions from byegad and after quite a bit of messing around I have got the wheel vastly better than it was. The only problem I have is that I was using a Topeak Hexus 2 multi-tool spoke key to adjust the nipples and this tool looks pretty poor has it has very small contact area with the spoke nipple, or maybe I am just crap as it was my first time (I have a feeling that I used the larger size first and ruined the flats, although the nipples seem to be made out of cheese on these Alexrims). Anyway one of the nipples is in a bad way and I could only adjust it with mole grips. So basically I have 2 questions?
1) Do I just need to buy spoke nipples or complete spokes, and how easy are these to replace?
2) What is a decent spoke adjustment tool that offers a greater contact area with the flats on the spoke nipple than what I am currently using?
Thanks for any help.
PoweredByVeg
Lingwood/Norwich
Just get the right length spoke nipple, LBS is probably the best place. They're replaced by removing tyre/tube/rimtape, unscrew damaged nipple (it's got a screwdriver slot if the flats are totally mullered), then refit new one.
Some people replace them dry, bit of grease or proper nipple lube, take your pick :whistle:
My link Halfords do this tool that I use, nice long contact area, but if you're in the LBS for nipp's ask them what they suggest :thumbsup:
It's satisfying to true and then build a wheel, try taking an old wheel apart and then rebuild it, if it goes all Pete Tong it don't really matter :wacko:
Make sure that you get brass nipples, not aluminium ones which really aren't up too the job. If you have a wheel jig you can pop it in and replace one at a time and true as you go, shouldn't have to worry to much about roundness and dishing if you're careful.
Cletus Van Damme
Cletus Van Damme
Thanks for the replies guys I will get some new brass nipples and a decent tool like the ones listed. You are correct gwhite I would definitely not think that my spoke tensions are all even after my efforts. But then again they were not before I touched it, one was slack as anything. I have read a bit on here about people complaining about the quality of these rear wheels on the Secteur. I was planning on replacing when I can afford it. Maybe I should take it to my LBS, but then again they might not make much of a better job, I dunno.
